brianjwilson
- July 8, 2004
- 98 Ranger, 05 Sport Trac
Hey everyone, I need some help with my rear Aussie locker. My truck is parked in front of my garage (in the alley) of my townhouse, been there since last night, neighbors aren't happy...
Short story:
Center pin is stuck. Locker doesn't fit in clearances...
Long story:
I received a warranty replacement for my locker, it doesn't fit with the side gear shims (thrust washers).
When I installed the first locker, same problem. I had to install it without the thrust washers, and the cam gear spacing was BARELY within tolerance (wide). Worked fine for 6 months, then started slipping all the time. Called everywhere to look for shim kits, different thickness shims, no luck. Everyone told me they always re-use factory shims, and you can't buy different thicknesses.
So I had a shop look at it, they somehow fit the original shims in there and put it back together, gave it to me without measuring the cam gear spacing (idiots). Still slips. So now that I received my new locker (after ups lost it), I pull the cover off, measure the spacing, it's only .130, and specs say it should be .145-170.
Removing the center was a ***** when I opened it, had to hammer it out from the back side and push and pull for 20 minutes to get it out. So I took out the old locker, here's how it looked...
Moving on... I installed the new locker, pretty easily, with the shims in place. Now it's time for the last step, installing the center pin. I measured the cam gear spacing first (still only .130"). It's 11pm and I decide I'll just try it and hope for the best. Start to slide the center pin in and I can't simple push it through. So I bolt the wheels back up and make sure I'm pulling the axle out as far as possible, still no go. So I decide to tap the center pin with a rubber mallet, fairly lightly. Tap tap tap, clunk, first part goes through the C-clip holder, hmm, okay. Well it came out this way. Tap tap tap, doesn't go in further. So I try to pull it back out, doesn't come out. F' it, I'll tap it in and see if it works. So I tap it in until the top of the center pin is flush with the ring gear, but unable to get it all the way in. I'm able to tap it back out to the first spot, but now it's pretty well stuck. Here's where it is...
I can't get it out now.
I'm ready to take the thing out and ship it back to aussie, but I can't get the center pin out. I've tried sliding an allen wrench through the center pin bolt hole and tapping it from the backside, but it still won't budge.
If you haven't seen the inside of an aussie, or need a reminder, here it is...
This is basically what you have on each side, and the centerpin goes down the center. In the middle of that is the c'clip holder (collar). that is what the centerpin is stuck between. Should I hammer the crap out of the pin and force it through, and hope it works? Or what can I do to get it out? Aussie locker has had horrible customer service through out all of this. I call and get a lady who doesn't know what a locker is, and I ask for a tech. It takes hours, in one case 2 days to get a response, no matter how much I call.
Please help with some ideas!
Thanks
Short story:
Long story:
Thanks
