Explorer Maintenance - Modifications - Performance Upgrades - Problem Solving - Off-Road - Street Explorer Forum Covers the Explorer, ST, Sport, Sport Trac, Lincoln Aviator, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
I just got my new cam position sensor and the top (sensor) part has the correct pins, but the 1/2 arc is totally different.. anybody have this problem?? Old on the left, new on the right.
98 - 5.0
That does not look right at all--
how would the tool even fit? Unless you have the tool for it also--
The sensor on left will block the hall gap for half a revolution, where it looks like the one on the right will do 1/4 revolution. It may possibly time the pulse to the same point, and, tighten it up ( Make it of less duration) , but I am not sure about that. I have never seen a flag like that before.
Earlier 5.0 (96~98) uses a 3-wire Hall Effect sensor; later 5.0 (99~01) uses a 2-wire Variable Reluctance Sensor. The two types of sensor are not interchangeable and require different vane widths and different synchronization tools. The wide vane must be used with the HE and the narrow vane must be used with the VRS. Your 98 PCM is set up for the Hall Effect, so you must use the HE and matching wide vane Synchronizer assembly.
Even though it is more expensive, I would buy only the OEM Ford sensor and/or Synchronizer assy. There are cheaper Chinese knockoffs (Dorman and other brands) but these have caused grief for many owners.
I think I have it figured out. The sensor is the correct sensor, the housing however is for the 99-01 5.0's. I paid 40 for the sensor and housing via ebay, made in china crap granted. But I will end up with the correct housing and sensor from ford for the same 40 bucks...shhhhh... It may not be the 'right' way, but its the only way to afford the outrageous prices they charge at the dealership.
On a side note, has anyone looked at the price for motorcraft plug wires at the dealership for a 98 exp 5.0?? $250 for SPARK PLUG WIRES.. Point made.
