gforceman
- April 7, 2003
- Virginia beach VA
- 2003 limited 4.6 V8
just installed my freshley rebuilt A4LD Parts replaced all servos, bands, seals gaskets , clutches and steels torque converter and modulator valve , i still have one problem i had before not as bad now but when tranny is cold it will shift from 1st as tranny warms up then it starts shifting from 2nd from a stop if i shut it off wait a few min it will shift from 1st again till it warms back up then when i stop and restart it starts from 2nd goes to 3rd then OD i noticed when coasting to a stop the tranny isnt downshifting back to 1st when warm , i can manually shift into 1st , i did remove the govenor and cleaned it up but do i need to replace it ??? can that be MY problem , i did check the spools in the VB they where all free i did a reading on the 3-4 solenoids they where good any thoughts THX !!!
