jlh3rd
- September 11, 2010
- new cumberland, pa.
- 92 aerostar
i'm new here......i did a search and couldn't find m a direct answer..
getting the abs light..and i can't find the test wire ( orange/black i believe)..
have a code 12 for the airbag...battery is good, clock spring has been replaced..and i've checked the connection for the sensor relay in the front
and now, for the problem i've had the longest ( years)....a soft brake pedal that pretty much goes to the floor...i can stop the van but cannot lock up the wheels..i have replaced:...the master cylinder 3 times (brand new) , bled the master cylinders and system, replaced the abs actuator, rear drums, rotors, pads and shoes, system also bled at dealership, abs sensor in differential........
thanks
thanks
