I'm replacing the rusted dogleg and a section of the rocker up to the front of the rear door on my '92 4 door Eddie Bauer. When you remove the outer rocker, there is an inner panel called the inner rocker reinforcement inside the outer rocker. Is this panel welded to the outer rocker or the inner panel that attaches to the lip of the floor? Do you need to replace the inner rocker reinforcement or can you attach the outer rocker directly to the innerboard panel?
