91Explored
- September 20, 2010
- Austin TX
- 91 Explorer w/A4LD
I did a rebuild of my A4LD following Glaciers writeup <Big Thanks> Also did the VB shift kit from Transgo. I have everything back together and re installed in Explorer. Initially had some overflow of transmission fluid. I had not started engine to move it in the transmission. After running up to operating temp and adding fluid to correct level I still seem to have a leak somewhere. I correctly re-adjusted Shift lever with transmission, originally I had connected it without adjusting it. Now I have a clicking noise when moving vehicle. Seems in the transmission. Any suggestions other than pulling the transmission again ?
