92 Explorer CEL, 113 KOEO code..... | Ford Explorer - Ford Ranger Forums - Serious Explorations
mrbigtime
las vegas
92 explorer
Replaced MAF, O2 sensor, truck is properly tuned up, --engine runs slightly rough at idle. 113 code points to a bad IAT, but I can't find an IAT on
the 92. KOER codes are 113 and 998. Anyone have info on this?
thanks
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
Hope that helps. Its right behind the TPS.
998 is a hard fault. Check it:
http://www.explorerforum.com/forums/showthread.php?t=160035
mrbigtime
las vegas
92 explorer
Thanks Dan!
Your picture did the trick. CEL is OUT. thanks!!!!
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
Good to hear!
