92 explorer fuel intake | Ford Explorer - Ford Ranger Forums - Serious Explorations
Location
The U.P.
Sault Ste Marie, MI
85' B2 XLT
In process of putting back together. Have two lines but only see the one hookup on the drivers side closest to the firewall. Can't locate the other to save my life. Assistance appreciated as manual doesn't show jack and searching on the net, well you know.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Kesp4.0
Los Angeles, CA
1993 Explorer XLT
the other line should connect to the pressure regulator on the passenger side towards the front
Term_14
LAS VEGAS
92 Ford Explorer XLT
there is one line that goes from the regulator to the feed line and the return line runs from the back of the lower intake manifold to meet up with the feed line in the front, you cant mess up as the feed line is bigger than the return line.
Location
The U.P.
Sault Ste Marie, MI
85' B2 XLT
ok so the lines are actually the same, but I did have one marked f & r for obvious reasons. Can’t find the regulator so I’ll have to get a new one. My guess is it was nasty so I pitched it......I’m in the middle of this mess that sat aside for months recovering from surgery, now it’s all a mess. I just don’t see how they reached, so we’ll see
Location
The U.P.
Sault Ste Marie, MI
85' B2 XLT
Let me ask this too please: main line that comes off fuel filter goes to regulator correct? Any wild chance someone can tell me the bolt size for the regulator to the rail? I’ve gone through my misc pile already
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
putting what back together?
A 1992 explorer has a 4.0 and has a return style fuel system
High pressure feed line comes into the fuel rail and pressurizes
Then the fuel pressure is regulated by the rail mounted regulator, the leftover fuel is returned to the tank
You say you are "in the middle of putting this back together"....
putting what back together? We might need some more details
Did you put a later model engine in? A fuel pressure regulator is not something you would just "throw out" it is part of the fuel rail in 92. IN 1998 they switched to a returnless system, only one fuel line.
Location
The U.P.
Sault Ste Marie, MI
85' B2 XLT
sorry, it’s a 92’ explorer 4.0. I have a new regulator, I’m sure the old one is buried somewhere. I did a fresh crate motor and trying to get this hunk going after a huge delay.
Term_14
LAS VEGAS
even on the newer motors like 93 94 have the same system but the injectors are bigger because in 93 ford went to a sequential efi instead of a bank fire in 91 and 92 models.
