Hello all,
Thanks for all the great info in this forum. I have a 92 explorer that is giving me some trouble. I just got it from someone and she said that she never had tranny problems with it. It was slipping in forward and reverve quite badly. I dropped the pan for inspection and a fluid change. There was the normal amount of clutch matter buildup on the bottom of the pan and the fluid was dark but not burnt and had no matalics in it.
After the fluid change and topping off of fluid, I have great reverse. If I shift the selector into Overdrive, the tranny engages but does not have the ability to move forward. In other words I feel the light thud and can get the truck to just start to rock forward and back playing with the gas. If I shift into Drive, however, the tranny pulls great and shifts fine. After getting into 3rd gear, I can shift into OD and OD operates great. It will downshift into third, but if the speed is lower, it will just slip when dropping into 2nd.
I can rebuild chevy turbo 350s and 400 in my sleep, but this is my first a4ld and I know nothing about them.
Any help would be great.
Thanks in advance.
Thanks in advance.
