92 explorer start issue. | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
1Graywolf
Houston Tx
92 explorer xlt
Can a test light be used to verify power?
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
The area in fuel injector harness where it splits, is a weird connection that can short to engine. Also, ecm have known to have problems with swollen capacitors. A noid light will tell you when if the injector harness is sending signals. Keep in mind this is a batch fire injecteion, meaning all injectors on each bank trigger together. They are not sequential. They share the same wiring, do a short will drag them all down
LG57
Katy Tx
1993 Explorer Sport
If it will try to run with gas sprayed in the throttle body, most likely the elec is ok.
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
Which engines/model-years does this apply to?
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
91-some 93 are batch fire injection. Some 93 models ( C A) had sequential injection. All 1994 have sequential.
Batch injection wiring share the same color wire pairs , side to side, while sequential injection has color coded wire for each injector
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Oh snap! I just remembered the injector harness connector is hidden and often missed. I'll have to look thru my vitamin d thread for a post number with pic. When I got it all back together it did this same thing. Found the unconnected connector
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Yes the red wire should be powered with key on and the pcm sends a ground pulse on the other wire
Good test before pulling fuel rail
With what you describe about the fuel tank abs lines it is quite possible an injector or two are plugged
You can also pull a couple of spark plugs after cranking and have a look, are the tips wet w fuel?
