electric88
- January 10, 2011
- North Las Vegas, Nevada
- 92 XLT 4x4
newbie here. have a 92 explorer that refuses to start, except when it wants to.the problem is intermitant start sometimes works with the key, but most times have to get out and pop the hood to jump the start relay posts. 3 shops, both ford dealers in town, and 2 mobile mechanics have worked on this problem (just over $4,000) to no avail. I have replaced starter, batt, start relay on fender, batt cables, ignition sw on colum under dash, and checked every wire i could find associated with getting the piece of junk started. i'm at my wits end and am about to drag it out in the desert and blow it up. has any one else had this problem? if so please help. as to the question" does it start in neutral?" the answer is it does nothing in park, neutral, or any position required to start. get a click then nothing. fuel pump and all other electrical work perfect. has a mind of it's own and starts when it wants, not when I want.
