hipocars
- December 7, 2004
- naperville,illinois
- '92 Explorer, Eddie Bauer
I'm diagnosing an inoperative fuel pump problem on my '92 Eddie Bauer Explorer. Can someone tell me where the fuel pump is physically grounded?
The fuel pump relay, PCM relay and inertia switch are good. I'm getting 12 volts for a couple of seconds, drops to 6.8 volts with key "on" at the harness connector that plugs into the fuel pump harness (normal condition from what I've read here). If there is a separate ground wire for the pump, where is it located and what color is it?
