92 explorer will not turn over
Nukedeestoys
1992 ford explorer
My vehicle ran fine until i let it run out of gas. Now it will not start.I filled it up half a tank then I swapped the fuel filter out and the fuel that leaked from the line was black. Do i need to swap out the fuel pump and flush the tank and line? Im out of ideas here, some help would be apreciated.
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Before I replaced the fuel pump, I'd put a fuel pressure gauge on it and see if it is generating any pressure. Can you hear the pump kick on when you first turn the key on?
Nukedeestoys
1992 ford explorer
Im not sure i can here the relay kick on when i turn the ignition. Ive had it start a couple times then die almost instantly.
