92 Explorer won't start. | Ford Explorer - Ford Ranger Forums - Serious Explorations
power_manager
Ronk.,NY
1997 Explorer
I've got a 1992 XLT (w/ 245cu in that has been sitting for a couple of years. After changing fuel pump, filter and starter brushes it finally started (barely) but very rough idle. Seemed to smooth out when warmer. Let sit again for a couple of weeks and will not start. Fires right up if I spray ether into throttle body and wil lcontinue to run if i continue to spray so I have spark. Measured fuel pressure at rail is 39psi and holding (pressure regulator good), noid light flashing on at least one injector (that I can get to) but does not even cough. gas is fresh. Vacumn lines all look intact. PVC valve is loose. Used to start with 2-3 cranks max. Any ideas?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
