92' power window cable replacement question | Ford Explorer - Ford Ranger Forums - Serious Explorations
bkonczak
Denver, CO
'92 E.B.
Have a 92' explorer with a power window problem. Rear window made a grinding noise before it went completely out. Heard motor still working so i figured problem must be something else. Took apart door and motor only to find that my type of motor was not the one pictured in my manual. It shows a lever arm system whereas mine is a cable spool system. The cables somehow got bound up in the motor and frayed to the point of breaking. Been trying feverishly to find just the replacement cables for the motor. Does someone know a place to order these from? Could also use some direction on how to re-spool and connect the cables to window.
