d.bright
- January 12, 2009
- Lilburn, Ga
- 2006 Eddie Bauer 2WD V8
Hey Folks,
Got a new issue here.
Background: Brakes were vibrating harshly when braking from 60+ mph, when I checked the rotors I found that they would be under spec after turning, so I went to Advance Auto and bought:
2 - New "Wearever Gold" rotors (3 year warr.).
2 - Reman Loaded Calipers (came with Motorcraft pads).
2 - Front caliper brake lines for good measure.
2 - New front bearings just because I've never replaced them.
After replacing everything last night and taking it for a test drive, I noticed that my pedal seems to go about half-way down to the floor before doing any "real" braking, I can feel it grab a little during the first 50%, but the real braking seems to occur in the last 50% of travel.
After the test drive, I decided to bleed the system once more, by starting rear-right - rear-left - front-right - front-left. Some nasty black looking fluid came out of the rear-left this time and I bled it until it was clear. However, no air came out of any bleed adapters.
I took it for a spin again, and aside from the smoke coming from the front right (I forgot to use brake cleaner on the inside of the rotor to clean the coating off) that scared the crap out of me for a minute, it was still doing the same thing.
I've been reading up on here and it seems that my issue is most likely one of two things, it is either a bad master cylinder, which doesn't seem likely because it looks like the previous owner installed a Bendix unit before I purchased it, it has a date written on it (6/7/2006) in marker and looks pretty new. That leads me to the other thing, this Sport has Rear ABS, and it has the module that is mounted on the frame under the drivers seat. I've been reading, and people suggest bleeding or replacing this unit. Before plopping down money for a new unit, I would like to bleed this sucker and see if it helps. But I can't find any procedure on how to bleed this thing!
Could someone please post the procedure, step by step on how to bleed the RABS unit? Again, 92' Explorer Sport 4x4 if it makes any diff.
Thanks guys!
Thanks guys!
