cdarmy
- April 6, 2008
- 92 Explorer XLT 4X4
Ok, let me just get to it:
Compressor - replaced less than year ago
Condensor - replaced less than year ago
Accumulator - replaced less than year and 1 month ago
Low/High Gas Line w/Muffler replaced a month ago
Evaporator - replaced yesterday
Orifice Tube - replaced 2 times less than a year ago and yesterday
Heating side:
Water Pump - Replaced 2 months ago
Thermostat - Replaced 2 months ago
Radiator - Replaced 2 weeks ago
Heater Core - Replaced 2 months ago
Clutch Fan - Replaced less than a year ago
Fan - Replaced 2 months ago
Prestone reverse flush kit
Have Manifold gauge set / Harbor Freight R-134 Vacuum Pump / Plenty of R-134 already gone.
Last year when I got the vehicle I replaced the Compressor/Accumulator/Orifice tube and noticed the orifice tube experienced black death. Ended up replacing the tube again and exchanged the compressor and changed the condensor out as well. Was working almost ok after vacuuming the system with pump and filling with just over 2 12oz cans but a check at a friends A/C shop showed that the High Side seemed a little too high. Ended up driving up to live in CT and noticed the system was getting warmer. When I ended up in CT the high pressure line had a leak in it and all the r-134 escaped and the line needed to be replaced. I replaced that last month along with new accumulator. After vacuuming and refilling the air just never got "cold". A week ago the high pressure released and spewed out 134 under the hood. So needless to say the pressure was just too much. I went out and got a new Evaporator/Orifice Tube since it has 195,000 miles and the only thing I hadn't changed was that. Well after new orifice tube/evaporator new r-134 and vacuuming the system, it still never got "cold". I didn't see the High High pressure I had less than a year ago and the top evaporator line was sweating nicely as well as the top of the accumulator except for the "cold" vent factor. I went and vacuumed out the whole system again got a scale and put in 2 12 oz. cans and a couple more ozs. of another all the time with the gauges attached from vacuuming to filling. Noticed that it was sweating when I had about 1 1/2 cans in (12 oz. sizes). Regardless it took it in slowly and since the manifold gauge hoses can hold up to 4 oz. I probably got just about 24 ounces in the system. However it is just not COLD! So tonight I hooked up the gauges and put a thermometer in the vents and I came up with the following:
Ambient Temp: 75
Max A/C switch setting
Fan setting low:
Low Side Temp: 38 High Side Temp: 147 Vent Temp: 50
Fan setting 2:
Low Side Temp: 44 High Side Temp: 153 Vent Temp: 55.5 trending up
Fan setting 3:
Low Side Temp: 46 High Side Temp: 154 Vent Temp: 58.1 trending up
Fan setting MAX:
Low Side Temp: 50 High Side Temp: 159 Vent Temp: 62 trending up
The accumulator/top of dryer have tons of sweat on them. I am completely stumped at this point as to why I can't get "cold" air. The only thing I can think of is that the compressor just can't get the variation in pressures. I don't have a blend door so it can't be that issue.
I am ALL EARS and am looking forward to what you other experts could add to help me get away from this obsession by solving it and move onto other things I have to get done. Thanks ahead of time!!
Carmine
Heating side:
Ambient Temp: 75
Fan setting low:
Fan setting 2:
Fan setting 3:
Fan setting MAX:
Carmine
