marragtop
- April 14, 2001
- balt, md
- 91, 92, 95, and 2000 xlts
I have a 92 XLT that is leaking gas pretty badly from somewhere near the gas tank. The gas appears to be running down the side of the tank. It only leaks when the truck is running, and leaks even if there is only a little bit of gas in it. Therefore, I’m assuming it’s leaking from the high pressure line coming from the tank, and not leaking at the top seal or a hole in the tank. Does this sound reasonable?
Can anyone give me an idea of how much work it is it inspect/repair the line? I really haven’t had to mess with any of the fuel systems on my Explorers, so I’m not sure what I’m in for. Also, if I need to replace the line, is it a dealer only part?
Any and all responses are appreciated. Thanks.
