chiefssc
- September 29, 2007
- Aztec, New Mexico
- 1994 xlt
Heres a stumper.
Your replies have gotten me this far. thank you for your help.
I have cleaned the IAC and MAF. I have replaced the fuel filter, fuel pump relay, and the spark plug wires.
I have checked the fuel pump pressure (35 to 40 lbs psi), timing, and compression. All are good.
I get two error codes: OBD I
O114 AIR CHARGE TEMPERATURE SENSOR HIGHER OR LOWER THAN EXPECTED VOLTAGE
O565 CANISTER PURGE SOLENOID CIRCUIT FAILURE
I have replaced a cracked hose on the canister, and the battery is a little low from trying to get the truck running. The engine cranks fine and starts immediately, but will not keep running. It dies within about 2 - 3 seconds.
Please help, This is my wifes' car and she won't give mine back until I fix hers'.
