- November 6, 2000
- 2018 EX Sport Concept
It's become apparent with the fitting leaks that the original system has shot o-rings, and it seems more worth my while to convert to easily-available R-134a, finally making the A/C system a DIY item rather than seek out rusty old cans of R-12 or paying hundreds of dollars to get ripped off at the local A/C shops.
I'd like to swap out both the longer discharge and suction line and the shorter liquid line to barrier-type hoses (with a R134a fitting on the suction line rather than an adapter fitting), and the receiver/drier and switch to one with an R134a fitting as well.
NAPA apparently has an R-134a discharge/suction line, but I've yet to actually see it to tell if it has the R134a fittings or not. Their online catalog just shows the same R-12 hoses from Four Seasons/Spectra that you can get everywhere else.
Anyone had any luck finding a pre-made set of R-134a barrier-type hoses for the 93-94? Do they just make R-134a discharge/suction hoses and the liquid line for the R-12 system works fine? Are R134a receiver/driers available or you just have to use the adapter fittings?
Finally, I haven't decided on whether or not to replace the compressor. Mine hasn't had any problems, and I assume despite the R-12 leaks, there's been enough oil to keep it lubricated.
However, the possible casing/housing leaks in the middle have me wondering if the o-rings are shot and I'd be better off with a new one while going to the trouble of converting the system. I know the rear leaks are just from the bad o-rings on the discharge/suction line. I assume it's more hassle than it's worth to rebuild the FS-10 compressor, rather than buy another?
