93 engine swap!!! | Ford Explorer Forums
93 engine swap!!!
Even back in the old days of carb vehicles……..there were always mods to be done when swapping……….trans mounts, engine mounts, expanded capacity and radiator placement, kick down levers, A/C plumbing, re-wiring, throttle cables, exhaust mods….etc.
And, today…………besides computer mods.......there still remains the problems of fabrication mods and problems mentioned above, etc........when you swap a V6 for a V8.
Aloha, Mark
PS.......I'm not saying that it can't be done with enough time and money. Though, will it be a "drop in"........I doubt it.
That engine may not be an HO engine. HO is what Ford called their "High Output" 5.0's. If it's not, then it might only turn 160-180 horsepower, which is really not worth the time and effort of putting in your truck.
I was always wondering if you could put a 5.0L engine/trans from an F-150 and adapt the explorer transfercase to it?????
thats ture rhett...but would it fit w/o many mods..like cuting stuff outa the way ect. and hook up with warn 1354 t-case? the engine and auto trans together is only 250.00 cheapest one i found with every thing..thats why im really thinking about it
Well $250 for a functioning engine and transmission seems pretty good, and cheaper than you could get a 4.0 OHV for, most likely. And you would be getting a better transmission. I'd want a HO 302 though, if it were me.
Let's see...You would have to enlarge the tranny tunnel a little, but that can be done with a hammer and some TLC...I believe you will need an adapter for the 1354, you can find out more searching this site. You should be able to keep your A/C and probably even your clutch fan. A 1" body lift helps for clearances but is not absolutely essential.
Fitting the headers might be a problem. Many people must have custom headers made, or use 96-01 Explorer headers with a little modification. You should search here for info on that, because people like 410Fortune have a lot more experience with this particular swap than I do.
Also often the heater box needs to be modified/notched. Again if ya want details you can find them on this site. Search for heater box and 5.0 or 302 or something like that.
Being a 1987 5.0, it is probably speed density or Carb. That's not a big deal, you just need to keep that in mind if you are considering computer chips, and what not.
