Matthew Linsley
- February 20, 2017
- Anza
- 1993 Explover XL 4x4
So I bought an Ex with 204000 miles and a cheap bracket lift to take out to KOH this year and beat up but after sitting in the driver's seat for a couple of miles I quickly fell in love, my first truck was a '88 B2, and decided to make it a platform for a serious expedition vehicle. My current problem is it ran great until it died on top of a dune in Johnson valley. The motor started to cut out while going thru rough chop so I stopped and tightened up the battery thinking that was the problem then I while I was climbing the dune it died on it started cutting out again then ran great then I stopped and turned it off and it wouldn't start, just turned over but wouldn't start. I got a tow off the top and was able to bump start and run very roughly down the trail for awhile wear it died again. I changed the fuel filter since I was getting a dribble out of the fuel rail shrader valve, fuel now sprays out but still won't start. I plugged in a spark tester and got nothing. got it home then changed out the IAC, CKP sensor, coil pack, ICM, TPS. It started ran around the block then did the same thing. I cleaned connections grounds and pulled apart a good portion of the loom to look for obvious damage but I am stuck I need more places to check or a good mech in the Temecula,CA. Help please.
