'93 Explorer: crank, but no start | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
Fresh gas will dissolve the gas sludge if it is in the fuel lines upto the injectors, cycling the fuel pump on a few times a day for 2 weeks will clear that up. I had it happen.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Removing the upper plenum on a ohv takes 12-20 minutes, its easy especially on a 93 with no egr
However to see the valvetrain your gonna need to remove valve covers too
Compression test
Fuel pressure test
After that I would want to remove upper plenum and fuel rail, see what gives in there. I would bench clean each injector
Fix4Dirt
Get a Load O' This Guy!
Los Angeles, CA
1998 XLT 4x4
true, forgot about that... i mean also they could see buildup thru the intake on the intake valve, but couldnt see exhaust... but with valve covers off, perfect time to check for skudge too! (not related to running, but something to do while youre there)
JohnCameron
Kingsport, Tn.
1999 Explorer EddieBaurer
Guys, I need your help.
I'm trying to start a '93 Explorer that was last started in 2009. The previous owner claims that at that moment the car was running fine (was not used after that because of taxes: ~1600$/year... which is a lot for Romania).
So, here is what works:
> I have spark
> I have fuel (new pump, new fuel filter, checked the fuel return line and the pump is working fine). I did not use the tank, I just connected a new fuel pump to the fuel filter and put it in a 5liters bottle)
> Engine crancks just fine
> I have signal to the injectors (tested with a LED on one of the connectors)
> No Check Engine codes
> New spark plugs
> I have tried to started with brake cleaner spray in the intake and nothing happens
(New air filter, new engine oil, new transmission fluid)
I have checked that safety switch and it is not activated (the one that stops fuel in case on a crash).
After a lot of crancking, nothing comes out the exhaust and, also, I took out one of the spark plugs and is bone dry and clean.
All I can think of is that the timing chain is broken and the valves are shut so nothing is getting inside the cylinders.
Any idea how I can test this?
Or what else should I try?
JohnCameron
Kingsport, Tn.
Did you spray brake cleaner into it? I’m not sure that burns. I am guessing that you meant carburetor cleaner. If not try that or starting fluid. Maybe you have a vapor lock in your line somewhere.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Vapor lock doesn't happen in efi systems with return style fuel rail just fyi
Zvony
Pitesti
1993 Explorer Eddie Bauer
I've been pretty busy these last few days and had no time for the Explorer. I coudn't find a gauge to measure compression, so I decided to buy one (around 20$) and I'm waiting for the delivery.
Yes, I've tried to start it with brake cleaner, thinking that should work. I think I have some carb cleaner so I'll try with that.
Fix4Dirt
Los Angeles, CA
1998 XLT 4x4
both shoudl at least make ti sputter... both are highly flammavle ;)
WhyFord0
redmond, OR
84 Bronco, (92 exp 4.0)
if timing is off, it wont fire... however, if it ran prior to sitting i wouldnt suspect theres a timing chain issue... the valves could have been stuck shut with carbon, but wouldnt that either break somethih, which you would hear something, or just prevent it from crabking? im really not sure on this one... i however suspect that it may be a timing or spark issue if it didnt cough at all... but also 410 has great reasijs to suspect fuel as well, so im not sure on this one! how hard is it to remove upper intake plenum on these ohvs? if so, it may be worth a looksie to see valves...
Any update? we swapped a perfect running 92' 4.0 ohv into a 84 bronco. wired in pcm and have fuel pressure/spark/crank it will cough after sitting but won't run. engine was gone through and resealed by a novice, but he had a chitin and followed it religiously.
WhyFord0
redmond, OR
Similar issue, 84 bronco swapped with a 92 exp 4.0. fuel/spark 100psi compression. crank no start. replaced coil/EDIS/ect.
update?
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
Does it run on starting fluid? What is your fuel pressure at the rail?
Zvony
Pitesti
Hello,
Sorry for the absence, I'm pretty loaded at work.
I had very little time for the Explorer and here are some updates:
- tested compression: ~95PSI
- tested fuel rail pressure (event though I'm not so sure that the gauge was working well): ~35PSI (my other Explorer starts fine with that amount of pressure)
- used some Brake Cleaner (again) and it fired a little (so there is spark)
In about 3 weeks I'll finish my current work related project and I'll be able to have some more time for the Explorer
Zvony
Pitesti
Update!
I took the injectors off the engine and cleaned them (I have some ultrasound cleaning device, something very cheap). I used gas and cleaned them for about 20minutes.
After that, put them back in and... IT STARTED! I have to admit, it was an awesome feeling!
It's the first time for me to make an engine start again after more than 10 years.
Mr. Alligator
Tampa, Florida
1997 XLT Explorer
Awesome! Thanks for update... That helps make this Forum great…. and congratulations!!!
Well done.
