FordRules1
- June 1, 2010
- Santa Ana, CA
- '93 xlt
ok hello to everyone im new here and am in need of desperate help , my explorer will randomly stall and die (but it will mostly do it while waiting for a red light or at a stop sign), it will do it few times accelarating , and has died only 1 time (out of the hundreds) on the freeway, (fyi over time it has gotten worst as in the stalls and dies happened more frequent) so out of desperation i took it to ford for a diagnostic ($114) and this is what they found:
OBD-1 Codes-
536 brake switch
629 Trans fault
157 MAF
211 IGN module or loom
542 Fuel pump or circuit (it has new fuel pump)
543 these were both labeled
556 together as wire harness
ok based on ur guys knowledge and expertise
what could be causing the random stall and dies, if not what to start replacing first , i hope i can fix this its getting out of hand thx all
OBD-1 Codes-
536 brake switch
629 Trans fault
157 MAF
