93 Manual TC and Hub swap?
kindaclean93
Location
good ol commiefornia
cali
1993 Ford Explorer EB
I know you guys have probably seen this thread a million times, but I've been unable to find one regarding my issue. What parts am I going to need, how long's it gonna take, and how much am I gonna have to hack off of my truck for it? I have the pushbutton low and 4x4 and it doesn't work worth a damn, so I'd rather just have it floorshifted.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
MrQ
Smokey the Clutch is, Missed Shift You Did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
In order of questions asked:
- 1354 t-case, manual shifter/boot/ base plate
- An afternoon
- Cut a slit in your carpet where the shifter goes/cut a small rectangular hole in your base plate if you can't find one from a donor.
- If you want the 4x4 lights, trace those wires to shift motor, buy the connector of rockauto and splice them in, connect to the sensor on the tc.
For the manual hubs, just search there are threads all over the place with the conversion kit part number, the various hubs that will fit, and how to do the swap.
kindaclean93
Location
cali
- An afternoon
Thank you! I'm assuming this applies for the automatic trans too?
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
Automatic, manual makes no difference. Past the tail housing on either it's all the same.
fordpickupman
Cascade, ID
94 XLT
71 F250 Fummins
I have a couple sets of the D35 locking hubs that I scavenged but don't need anymore since I swapped to D44 outers that I'd sell.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Just in case you haven’t fully diagnosed the issue, you could find some good info to narrow down where the problem is. Might just be blown auto hubs. List of Useful Threads - 4x4 Troubleshooting guide
That said, I did the same swap on my truck years ago, the hubs are an easy swap, the tcase a little more involved, but basic mechanic skill will easily get you through it.
Most important is to find a manual case with the complete shifter including the bolts for it.
