93 ranger xlt 4x4 problem | Ford Explorer Forums - Serious Explorations
LMJ001
capital area ny
93 ranger xlt
i have replaced the t-case shift motor and have 2switchs and 2modules that do the same thing the test light comes on after i turn the key switch off and with the switch on i have no 4wheel driver the lights dont come on switch or dash the test light on the module dont work with the key on what should i check also the speed sensor wires shows positive should that be right and the magnitic clutch wire shows negative
cool
found the problem if any one has the same thing happen there is a ground wire under the carpet just in front of the drivers seat
