s-zero
- October 22, 2008
- cowtown
- 93 explorer
Need help with a 93 4.0L explorer. Only stalling when engine is cold and put into any gear. Fast idle seems ok, approx 1300rpm and comes down when warm. Symptoms only for the first minute or two depending on how cold it is outside. Replaced the MAF and cleaned the iacv. Fuel pressure and injectors ok. Dont think there is a manifold leak at this time, disconnecting MAF makes no difference. Anyone think it might be a tranny problem, ie lock up solenoid leaking? Any other ideas or suggestions. No codes with KOEO or anything else stored. Thanks for the ideas and input guys.
