93 xlt 4.0 rough idle issues | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
So, good information. Fuel pressures are all nominal. The funny thing is that your engine seems to like low pressure. Why. Fuel delivery depends on pressure and the amount of time the injector is open. So, it seems to me that the injector is open too long. What controls the injector? The computer. But, the computer is not talking anymore. That's 2 strikes on the computer.
Computers are less than $50 on ebay, and not a bad spare part to have around. A more intermediate step would be to test wiring at the computer, make sure it has good power, ground, all that good stuff.
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
FEAR30X
NEW JERSEY
93 XLT
Installing BackUp Ecm in morning after codes are run again
FEAR30X
NEW JERSEY
93 XLT
update ecm swap proved to solve issues, i still have a hint of low noise popping in the exhaust at times
udate[/u] psi 34-36 koeo
psi 28-30 vac on at idle
psi 38-40 vac off at idle
psi 36 hold 5 minute
psi 28-30 runs rough,
then remove fuel pump relay pressure drops sorta slow and
begins to run normal until it hits (zero)
oldpost 93 xlt 4.0 rough idle issues
93 xlt truck starts up and runs rough,warm or cold doesnt matter
truck runs like new 2-5 seconds after (fpr)= fuel pump relay is removed,
which then it stops loading up on gas and idles fine
f-pressure tested normal
no codes, cel does work
parts replaced or tested
new fpr,
new tps,
new coolant temp sensor=(solved black smoke issue)
new plugs,
new wires
fuel filter
justin_b31
Salt Lake, Ut
'93 XLT & '02 XLT
Where did you buy the ECU?
FEAR30X
NEW JERSEY
93 XLT
There's one reason why I don't like exhaust problems... I can never spell 'exhaust' right! Anyway, poping is unburned fuel. New computer, do you get check engine lights at all?
DREADED C.EL. or check engine has retired for now,
no more problems pop is gone,
runs like a new truck, lol now on to gas gauge intermittin problems & maybe anew UnCracked fans
