ornithology
- January 20, 2009
- Vancouver, BC
- '03 X Sport2dr 4.0 V6 XLT
I'm trying to tweak the truck to get an increase of mpg. I'm going to change the fuel filter, and also get an oil change done with Mobil1 Synthetic 5W30. I live up in Vancouver, BC and the temperature is averaging between 2-6 degrees now.
Anyways, my main question is I only have 93,000 kilometers (57 miles)on the engine. Wondering if I should add some ATF do clean it? I'm wondering if any "sludge" or "grime" could be there holding the engine together and if the engine cleaning with ATF would remove this, thus causing a damaged engine. Should I do this or not?
I guess while we're at it, is 5W30 sufficient for the temperature around here or should I opt for the 10W30? I'm also wondering if I should go for the Mobil1 ATF?
I have an 03 Ex Sport V6 4L
