94 4dr 42's d-60's 302 c-6 | Ford Explorer Forums - Serious Explorations
Vozar
Murfreesboro,Tennessee
94,98 & 03 explorer
Havent been on the boards in a while and Im starting a new project. Got the explorer for free and axles were under my other explorer.
Specs:
89 town car roller cam 5.0
Gt-40 heads
Comp cam(undeciede yet)
Summit stage 1 intake
Propane
Fairbanks built c-6
T-case undecided(mabye 203-205 doubler or 1356 doubler)
D-60's are welded with 5.38's, disc brakes f&r
Exo-cage
4-link front
Stock leafs soa rear with warriors
Traction bar
Full hydro steering with danfoss orbital and tractor supply ram
42' tsl's on 15' diy beadlocks
and a few things im missing
no body lift and lots of fender trimming!!!
trying to keep this a low and stable as possible
ordering a bunch of parts this weekend
heres a teaser pic, rear 60 in installed and front ttb junk is out
:D:thumbsup: watchin' :D:thumbsup:
subscribed
so have you had any progress on your build? its been a while
some progress....
4.0 out and 5.0 in
pieced together propane kit
ended up doing gt-40 heads with trick flow spring kit
trick flow stage 1 cam
summit stage 1 carb intake
heddman v8 swap shorties
advanced adapters v8 swap motor mounts(fit like crap)
hei style distributor
msd wires
street fire ignition box with rev limiter
propane setup
front links- johnny joints with 2" 1/4 wall links
snagged a fresh built c-6 and np205
Rear d60 30 spline chromo yukon shafts, front 35spline chromo outers, drive flanges and spicer joints
1356 crawl box from behemoth drivetrain
getting there, c-6 in, crawl box in, mocking up links, still alot of work left
O wow , That Will Be a Beast When Done , Staying Tuned in for this one ! , Sweet Rig and Plans ! .
