cobraphx
- February 14, 2006
- Phx
- 93 Eddie Bauer 4x4
So I bought a 94 4 door Explorer 4X4 with a bad performance rebuilt A4LD. I did a lot of reading and decided to do a Frankentranny rebuild myself. Before the rebuild the tranny would not move the truck in forward or reverse.
So, I bought all the 5R55 internals, a bellhousing, and a rebuild kit with new frictions and bands. Replaced the rear race, and went thru the valve body. Everything went together nicely. Put it back in the truck, along with a new TC. And it was better. But far from right. It moved in forward and reverse. But it was hesitant to move, took about 2500 to 3000 rpm to get it to move. It shifted, but felt like a manual with a slipping clutch.
So, I figured maybe my rebuild of the modified valve body might be a problem. Ordered a rebuilt VB and replaced it along with upgrading the low reverse servo with the D shaped o-rings. Had to tap it in with a rubber mallet to compress the spring. Not sure if that is normal or not. Tested again... Sounds like forward engages better, but still takes a bout 2200+ rpm to get it to move. Now reverse is a problem. When shifting from park into reverse, no engagement. when shifting to reverse from neutral it seems like there is an extra detent right in the middle of reverse. If I shift it further to where reverse should be still feels like neutral.
So... Not sure where to go from here. I haven't adjusted the OD and intermediate bands since it was on the bench... but I don't think that would effect first and reverse. I didn't touch the vacuum modulator, just reinstalled it set the way it came off.
I have a feeling it will have to come back out. Trying to decide if I should just buy a rebuild, or try and find someone that could actually fix the Frankentranny. I think most shops will tel me they have to replace everything (since it isn't A4LD internals) and charge a small fortune.
Any advice would be welcome.
-Matt
-Matt
