IAmTodd
4x Explorer Veteran
- April 8, 2002
- Johnstown, PA
- 2015 Jeep
I'm trying to clear up all issues on my truck before winter rolls around. I've had an intermittent ABS for the entire time I've driven the truck. It's on more than it's off though. I've never tested the operation of it when the light is off. Sometimes it's off when I start the truck and after a mile it turns back on, sometimes it's on immediately after starting.
I've tried the jumper wire method on diagnostic port between the BL and LB/BL wires, turn the truck on and wait 5 seconds and pull the jumper. The ABS light stays solid, no codes flash. Would that indicate a controller issue or am I doing the test incorrectly.
I'm getting ready to pull the axles so I'll have easy access to each sensor. Is it possible to test them buy measuring the resistance?
