rguy
- August 19, 2004
- Republic of Texas
- '91 Explorer 4x4
I tried to research this problem but wasn't able to find anything similar to may help.
This is the history...I swapped out the auto transmission from my '94 Explorer for a 5 speed and swapped transmission harnesses, but left the original ECM in it. I wouldn't bet me life on it, but I'm pretty sure that before I started the swap, the xfer case would go into 4LO when I pushed the button. Now, the xfer case will only go into 4HI. I checked the transmission harness to make sure the correct wires complete the NEUTRAL circuit.
What could cause this?
Just to verify... with an auto transmission, doesn't the vehicle need to in PARK or NEUTRAL before the xfer case will shift into 4LO?
The ECM wouldn't have anything to do with this does it?
Any help would be appreciated.
