94 Explorer Coolant Leak | Ford Explorer Forums - Serious Explorations
mfitz725
03 EB 4x4 4.6l making it thru in NC
Location
Albemarle NC
Albemarle NC
'03 Eddie Bauer 4.6L 4x4
I may be going about this wrong and apologize if I double posted my question. I am used to reading postings for all the helpful information they contain bu this is my first time actually posting a question.
I have leak coming off the back side of the engine. Engine does not have to be running as long as the system is full, it leaks. When the coolant runs down it is dripping off the right side of the oil pan right in the area of the drain plug. All my attempts to see where it is coming from have failed. Any ideas? I fear it might be the intake gasket, but need a way to check so I'll know what to do.
Most auto parts stores rent cooling system pressure test kits with a fully refundable deposit.
By far the best method of pinpointing leaks without buying unneeded parts. Call around. GL
