94 explorer lift question | Ford Explorer Forums - Serious Explorations
Daniel77
Ohio
94 Limited 4.0
I have a 94 explorer limited that I would like to do a 5.5 ' lift on .
I was told that I would have to flip my rear axle and use blocks
to lift the rear . Is this possible ? I am looking at the super lift
suspension lift kit . Does this kit come with everything to do the lift ???Thanks to all that help
Joey
to lift the rear
You don't actually flip the axle around... What you do is convert from a spring under axle to a spring over axle (SOA). By doing that alone you get 5"+ inches of lift.
You can buy the superlift kit which is pretty much bolt on and some people have left their like that or go the other route where you weld on new spring perches on the axle so you can put the springs on top of the axle. This is the SOA perch/u-bolt/plate kit I used... http://www.ruffstuffspecialties.com/catalog/88SS-31.html
In short, most 5.5" lift kits come with some way to do a SOA in the rear while 4" lift kits keep the spring under the axle and use new springs.
~Mark
thanks maniak, This is a big help . I am looking in to buying the lift kit this year ,
maybe in the fall and make it my winter project next winter . I will buy this axle
under kit too . Thanks again joey
94 explorer 5.5 lift
Morning guys . crispy but sunny here in Lima ohio. (26 degrees)
Here is the lift kit I am going to order
http://www.superlift.com/lift-kits/...rer-navajo-superunner-suspension-lift-kit.asp
I need $ 25000 to order it .
Will keep you all up dated on how its going . May need some help .
Till then ,hope you all had a nice xmas and new year .
Hope 2015 will bring us all great blessings.
Thanks again maniak for heads up on these ao brackets .
I think this kit comes with them.
Joey
