94 explorer limited, front end wobble
Jromero777
I live in sedona az now grew up in San Diego CA
94 Explorer Limited
Well i took my explorer to a shop for the wobble, it kind feels like a loose tire or a warped tire on a bicycle, they told me i needed an passenger side tie rod but wanted 150 to install it, my dad and i put it in for 40. front end wobble is still there, on a suggestion from a friend we rotated the tires to make sure that is wasn't an out of balance tire. still there. any other suggestions. This is my daily driver, i need to get it fixed.
thank you
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Jason94sport
South FL
02 Sport 2WD 5 speed
Bad shocks, worn bushings, Ball joints
rustbucketMI
Michigan
'94 XLT 4x4
If you checked the tie rods its probably ball joints like Jason said. Check the forum for other threads like this. I seem to remember reading a very similar thread a couple weeks ago
Everdream
Lakewood WA
2002 Explorer Limited
if its totally horrid, radius arm bushings can cause it to wobble around, but it would also clunk loud like a blown cv axel on whatever side. this bushing is at the end of the Y shaped pipe going from the front wheen towards the back of the truck into the cross member (look half way down the tire, pointing backwards) Mine are blown and the truck also "waves" around a little on the freeway.
Jromero777
94 Explorer Limited
Wobble is at any speed but seems to level out at
speeds above 35, there isn't really any noise associated with the wobble, i am leaning toward it being the ball joints, just have to wait for payday. I assume its not to safe to drive it so its been the bus that last couple days. I need to get the front and back suspension done soon too. when we did the tie rod we noticed that the arm was a little loose too, that why i am thinking the ball joints after checking some of the other threads here.
thanks guys any other suggestions or easy ways to do the ball joints would be great
thanks guys
cogs
texas
'94 sport 2wd
ball joints replace
i'm interested in how hard was it to do the tie rods? did you get an alignment, or what? (i'm about to replace mine).
Jromero777
94 Explorer Limited
Tie rod was easy...
Just make sure to measure and keep everything the same length, messed that up on a camry a few years back, once i get all the front end stuff done i am going to get an alignment done but havent yet, just eyeballed it lol
W 1994 Explorer Limited Coolant Leaks Stock 1991 - 1994 Explorers 8
ghosttrain2 1994 Explorer Limited- yes I bought another one... Stock 1991 - 1994 Explorers 18
V Weird Transmission Filter Question 1994 Limited Edition Explorer Stock 1991 - 1994 Explorers 2
V Anti-Slosh Module 1994 Limited Explorer Insturment Cluster Stock 1991 - 1994 Explorers 6
V Ball Joints On A 1994 Limited Edition Explorer Stock 1991 - 1994 Explorers 16
V 1994 Ford Explorer Limited Edition Stock 1991 - 1994 Explorers 7
mgmgmg 1994 Ford Explorer Limited Stock 1991 - 1994 Explorers 22
J 1994 Limited Ford Explorer with 4x4 issues Stock 1991 - 1994 Explorers 8
F 1994 4wd explorer; rear LIMITED SLIP differential Stock 1991 - 1994 Explorers 1
M New to the forum and to the explorer; Headlight issue and acceleration issue on 94 explorer limited Stock 1991 - 1994 Explorers 2
J 94 Explorer 4 door limited, I may have killed my transmission. Stock 1991 - 1994 Explorers 7
P I need a back seat for a 94 Explorer Limited in So Cal Stock 1991 - 1994 Explorers 3
L 1993 Limited explorer seat swap with xlt? Stock 1991 - 1994 Explorers 3
J No Start - 1994 Ford Explorer Limited Stock 1991 - 1994 Explorers 6
B Limited Slip for 91 explorer Dana 35 IFS??? Stock 1991 - 1994 Explorers 15
M 1994 explorer limited Stock 1991 - 1994 Explorers 1
L '94 Explorer Limited steering/handling problems Stock 1991 - 1994 Explorers 2
P 1994 Explorer Limited with Bad Ping Stock 1991 - 1994 Explorers 9
9 1994 explorer limited speaker help Stock 1991 - 1994 Explorers 2
S 94 Explorer Limited A4LD Tranny leaking Stock 1991 - 1994 Explorers 0
T Fixed starting problem 94 explorer limited Stock 1991 - 1994 Explorers 3
T Mystery connector on a 1994 Explorer Limited. Stock 1991 - 1994 Explorers 15
D 1994 Ford Explorer Limited. Stock 1991 - 1994 Explorers 8
T 1992 Explorer Limited auto 4x4 push button Stock 1991 - 1994 Explorers 3
G grill/brush guard 93 explorer limited Stock 1991 - 1994 Explorers 0
E 1994 explorer limited Stock 1991 - 1994 Explorers 10
M Question about 1994 Explorer Limited Bumper Color Stock 1991 - 1994 Explorers 13
K 94 Explorer Limited... FAQ (expert advise please) Stock 1991 - 1994 Explorers 1
3 94 Explorer Rear Noise Stock 1991 - 1994 Explorers 12
C Need help with a 1994 Explorer parking brake parts Stock 1991 - 1994 Explorers 4
kindaclean93 1993 Ford Explorer 4WD issues Stock 1991 - 1994 Explorers 5
Z Happy owner of '92 Explorer Stock 1991 - 1994 Explorers 16
B Flat Towing 2000 Ford Explorer XLT Stock 1991 - 1994 Explorers 0
B 93 Explorer won’t start with key Stock 1991 - 1994 Explorers 4
E 1994 Explorer 4x4 leaky trans Stock 1991 - 1994 Explorers 2
A 1992 Explorer. Fuel pump or MAF Stock 1991 - 1994 Explorers 21
S Can’t find the hood cable on my ‘93 Explorer Stock 1991 - 1994 Explorers 0
R 92 explorer fuel intake Stock 1991 - 1994 Explorers 7
F 94 Explorer hesitation/bogging down Stock 1991 - 1994 Explorers 24
M 1994 Explorer 4x4 engaging while turning Stock 1991 - 1994 Explorers 11
N Pulling the A4lD tranny on my 91 explorer. Stock 1991 - 1994 Explorers 2
E 1994 explorer doors and 94 ranger doors will they fit Stock 1991 - 1994 Explorers 1
D fixed a few things on my explorer. Stock 1991 - 1994 Explorers 3
T 93 explorer starter wiring routing Stock 1991 - 1994 Explorers 7
F How Do I Remove the Dash Bezel on a 1992 Explorer Stock 1991 - 1994 Explorers 1
D Help explorer 94 Stock 1991 - 1994 Explorers 2
K Wanted 1992/1993 Ford Explorer for filming in the Boston area. Stock 1991 - 1994 Explorers 14
F 94 Explorer A4LD - What's to lookout for? Stock 1991 - 1994 Explorers 14
F 1994 Explorer Differential Cross Pin Stock 1991 - 1994 Explorers 6
V Vacuum Line Kit 1994 Ford Explorer LE Stock 1991 - 1994 Explorers 1
Similar threads
