MailmanP
- August 18, 2019
- Crawford
- 1994 Explorer
I have a 94 Explorer that wasn't shifting right from 3-2. Read that the vacuum modulator was probably bad. When I pulled the vacuum hose off, fluid drained out indicating it was bad. So, I changed it. The new one is an adjustable one. Now, no matter how much either direction I try to adjust it, the transmission is way worse than it used to be. It's all gears now. Yes, I did put the pin from the old to the new. What is going on????
