D
Deleted member 279606
Help Needed. My explorer has starting running high for the 3rd time in about a year. When I say running high, I mean the rpms are offset 1-2k high, both in park and drive. It takes extra brake pressure to come to a stop and when I let off the brake, it self accelerates. It's as if it wants to run itself at @35mph, depending on the incline of the road. When I put it in park, after driving long enough for it to warm up, it revs way up to ~3krpm until I turn it off. The CEL is not on.
The first time this happened it was accompanied by a whining sound when turning. I found the power steering fluid was low, and when I refilled it, it fixed both problems. It was as if the engine was trying to pull nonexistant fluid constantly, creating an extra load on the engine. Problem solved, or so I thought...
About 9months went by and it happened again. All fluid levels were good. I checked and cleaned the IAC and throttle valves (it was remarkably clean to start), I checked the TPS and it functioned nominally. There was nothing wrong with the throttle cable. Eventually I cleaned the MAF, and after a few drive cycles it ran normal again.
That was about 2months ago, and now it is happening yet again. I don't hear any vacuum line hissing sounds, but it could be that I just cant hear it over the roar of the engine.
Not sure if it's related, but I'll also add that it takes several turns for the engine to start up, more when cold, even after I replaced the battery.
Thoughts? What else can I try? Thanks!
