Relvie
- May 8, 2012
- 94 explorer
Hi guys I was wondering if anyone might be able to help with a problem I'm having. I have a 94 explorer 4.0 4x4 it runs and drives great except when its hot outside and I start to slow down for redlights.. ect. it ill drop rpm's almost to the point of stalling. No matter how much I press the gas or put it in neutral and try to rev it up it just continues sputtering often times completly stalling. I have to turn it off and restart it to get it to stop.
I've replaced the fuel pump and filter, MAF sensor,tps sensor, iac valve, checked and fixed any vaccum leaks, seafoamed it, run constant injector cleaner, I've taken all of the intake manifold and fuel injectors off and cleaned it all. Gutted the cats. New plugs and wires. New voltage regulator and both coolant sensors.
I'm still getting the same sputtering and stalls only when I slow down. When its up to speed it runs great. Also it seems to not do it when its cooler outside. On hot days its sputtering within 15 minutes of driving. I have tried researching this problem and cannot seem to figure it out. Anyone have any ideas?? Any help would be greatly appreciated. Thanks. -Mark
