MrShorty
- December 27, 2001
- Spanish Fork, UT
- 92 XLT and '87 Bronco II
In most cases, there isn't a test for a bad PCM. You determine a bad PCM by process of elimination. If every other possible cause is eliminated, then the PCM must be bad.
Aside from that, the other "test" for a bad PCM is "guess and check" In other words, replace with a known good PCM and see if it fixes the problem. This isn't bad if you can return the replacement if it doesn't fix the problem. Not as desirable if it costs a bunch to test. Especially because, as you say, the PCM doesn't fail that frequently.
