Robex94
- March 15, 2012
- Wichita Kansas
- 1994 Ford Explorer XLT
Okay, so I have been researching on here like crazy and I have found some great help on how to resolve my fuel problems, so hopefully I will be able to get some help on this one.
I have a '94 Explorer XLT 4X4 that has been intermittently failing to start and failing to continue running. It hasn't show any consistent reason for failing except for that it fails after getting warmed up.
I changed the fuel pump and EEC relay and it fired up and ran wonderfully. Then after a week they failed. So I got on here and found out that aftermarket relays are prone to fail and that I should use Ford relays. I bought some off an Explorer at a salvage yard (5 for $20 was better than 1 for $25 from Ford) and they worked wonderfully, until today when they failed me 3 separate times. So I took apart on of the aftermarket relays, stuck it closed and it fired up but ran kind of rough at 60mph. I am going a bit mad trying to figure the problem, does anyone know why a relay would continue to fail? Am I barking up the wrong tree entirely? I am pretty sure it is the relay because every time I put in a new one or jump across it my Explorer fires right up.
I am sure that I have left out information for the sake of brevity, but if anyone could help I would definitely appreciate it, and if you need any more info I will be sure to get it to you. Thanks in advance!
