nightsfire
- November 7, 2010
- acworth,ga
- explorer 94 SPORT
lets start off with hi I'm new here been scanning the forums last few days and decided to finally post because i am stumped
lets start with i have a 94 ford exp 4 speed with overdrive stick shift 4.0L
the problem i am having with it is when its cold/not warm it runs fine if you ease into the gas pedal runs fine and shift before 2k + rpm if you get over 2k + it starts bogging the farther you push the pedal the more it bogs if you try to take off pedal to the floor it bogs after 20-30 mins driving
it starts bogging at all times i can only get up to 15-20 mph if i apply any more gas it acts as if the engine is going to die it doesn't die tho even if i floor it its like on the edge of dying....
also when trying to start it cold or when it has been sitting for a few mins it does not want to start it will start with REAL low rpm 200-500 then die and i have to keep cranking it finally it will start and jump to 1.5k rpm then slowly go back down to 1k rpm
i also have the great old check engine light koeo test it comes up with code 214 but i dont think it has a cps least not to what autozone says... i am truly lost on this one and trying to get it running right before Tuesday or will have to use dodge for my job @.@
thx for all help
thx for all help
