My 94, has a problem starting, the fuel pump doesn't turn on when the key is turned on. A dealer put it on the computer and it said that the fuel pump was bad, so a new one was in. The problem still exists. Also put 2 new fuel pump relay switchs in and nothing. Sometimes it will work, you shut it off and try it again it won't start. Running out of ideas, any ideas would be great. Thanks.
