8th
- November 16, 2015
- 1994 explorer
Battery has been tested and charged
cables cleaned, terminals replaced
grounds checked, cleaned
starter solonoid replaced
Fuel pump switch has been reset
Fuses/relays are good
The truck had no issues prior to this, I left the key in the "on" position overnight, battery was dead so i had it charged and tested and now im having this issue.
I can get power to the fuse box and allow power to lights, seats.etc if I jump the large ends at the solonoid, I can also activate the starter if I jump the starter wire. When the solonoid is jumped and I leave the starter wire in the original position on the solonoid turning the key activates the starter but there is still no start.
I replaced the fuel pump only a couple weeks ago and has not been giving issues. I do NOT hear the pump run when switched to the "on" position, Plugs and wires are also new but there is no spark, haven't had any rough idling or running issues beforehand. The only thing I can think of now is that some sort of security system has engaged and won't allow it to start? I honestly did not think there was a security system in this truck but with some research I guess there is a module in the quarter panel. I will try messing with that tomorrow but if that doesn't work I'm completely stumped.
