HxCGuitars
- January 12, 2012
- IL
- 94 XLT Ranger
Hey guys, got another thing that's kind of stumping me that I wanted to ask here first about.
I've noticed for a while that I've been leaving drops of tranny fluid wherever I go. I'm sure my trans pan gasket isn't in the greatest of shape, but when I crawled under to narrow down the leak, it was dripping off the bottom part of the bracket on the side of the trans that moves when you shift between P,N,D, etc.
Now this is where it got interesting. I cleaned it off to narrow it down, and it looked like it was coming from right underneath the bracket where it mounts to the side of the transmission. Now when I bought the truck, as I went to drive off, I was told a cable dry rotted that kept me from being able to shift gears as when you went to shift gears the lever was completely free and didn't engage anything.
It looked clean under the bracket, almost like there might've been gunk there keeping it from leaking before, and it had been cleaned when they put the new cable in. The bracket itself has a good amount of back and forth play, is it supposed to be loose? Almost thought maybe it had to be tighter to seal against the trans, so I attempted to tighten the bolt on top of the bracket and it didn't seem like it was doing anything, so before breaking something I figured I'd ask here. Is it even possible to leak out there?
Thanks in advance. Slowly getting my Ranger to satisfactory condition haha.
