94 Ranger ignition question (Code 224) | Ford Explorer - Ford Ranger Forums - Serious Explorations
rmileham
Brookings, SD
1994 Ranger SuperCab
I have a 94 Ranger SuperCab, 2WD IL4 5 Speed Manual. I bought it a few months ago and it has at least 140,000 miles on it. The motor misses under a load especially when at full operating temperature. Checking CEL codes yields the following:
KOEO: 337
CM: 224, 337
KEOR: 337
Inspection of the DPFE shows corrosion around the pressure inputs (its case is Aluminum). Posts on this forum indicate that moisture is the enemy of the DPFE. Therefore, I have one on order. That should cover 337, I hope.
224 points to the primary coil. I used a timing light to monitor the spark on each of the plug wires on both coils. Several showed consistent firing while the others were intermittent. On one of the intermittent lines, I pulled the plug wire from the top of the coil, thereby forcing the spark to jump from coil to wire. Doing this resulted in the line firing consistently. It has been a long time since I have done any trouble shooting, but if my memory serves, this is an indication of a bad plug / wire.
So here is my question: Can the 224 code be indicative of bad plugs and wires?
Sorry for being so long winded. Any advice is greatly appreciated.
rmileham
Brookings, SD
UPDATE
It looks like the answer to my question is: Yes, bad plugs and wires can produce the 224 code.
I replaced the DPFE, plugs, and wires. The miss is gone, no CEL, and all 111 codes.
Life is good!
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
..Glad to see this worked out and thanks for posting an update as I'm sure it will help others looking for answers to this same problem..:biggthump
