Matt Fisher
- November 26, 2005
- Visalia, CA
- 94 Limited
I'm going to try and include as much info as possible, so this may be a little long. Thanks in advance for your suggestions.
94 X 170K. For about a year now, it's always had the occasional need to crank on the starter more than once, or for a bit longer than I'd like. In the last 2 weeks, it's gotten worse, and sometimes will cut out while driving down the road. 3 days ago it took 20 minutes for it to start, has gotten progressively worse, and as of this morning, it's DOA.
However, I haven't ignored the issue, and have replaced the following items:
-New plugs/wires 6 months ago. Today I tested for spark by removing the plug wire off #1, putting a spare plug in there, laying it against the fender, and cranking the key. Sparks like mad. Pulling the actual #1 plug shows it to be black and sooty (keep reading for ideas as to why it's not light brown), but it's not wet.
-Used ECM 5 months ago. The last one had a stroke and caused the CEL to stay on. My CEL is NOT on at this time, and has not come on (except during cranking) since the new/used ECM was installed. New 02 sensors then too.
-3 days ago when it took 20 minutes to get it started, I took it into a local shop. It was running horribly, and wouldn't hardly idle. They diagnosed a bad MAF (said that it was running unbelieveably rich), and replaced it with a new one. It ran better, but did cut out on the freeway a few times. I did notice that the hard starting issue was most prevalent upon shutting the vehicle down after only 2-3 miles of low-speed city driving; not totally warmed up.
-New fuel pump/filter 2 months ago. Today I became convinced that the pump was the issue, and swapped it out again- to no avail. Also today after pulling the codes, I also replaced the crank sensor- still not starting. When the shop had the rig 3 days ago, they tested for fuel pressure and said it was fine, I thought it was possibly intermittently bad pump. Fuel pump relay clicks over just fine, I even tried jumping it and leaving it on while cranking it over.
-The KOEO codes that came up are: 539, 21 and in memory- 542 & 211. Obviously the vehicle is cold, and no KOER could be checked.
-The fuel pressure regulator holds vacuum. Depressing the schrader valve does result in fuel spraying out.
-New TPS 5 months ago.
When I first try cranking it over, it acts a little bit like it wants to start. Continuing to crank on it does nothing. In order to get it to run for 1-2 seconds, I have to wait a couple minutes before cranking it over again. What convinced me to swap out the 2 month old fuel pump even though the shop said it was fine was getting it to run for 5-6 seconds on Engine Start (ether). I sprayed it down the intake while my neighbor cranked on the key- it did run for a few moments. This only really worked once, and I've used up 3/4 of the can today- this may also explain the black spark plug I mentioned above. An occasional mild backfire does occur. This does result in blowing the hoses off the vacuum tree, but I re-install them. Yesterday I did happen to listen for vacuum leaks, and did not hear one.
Excepting the occasional refusal to start, and the odd/intermittent cutting out on the freeway, it's been business as usual. Not much power, and consistantly lousy fuel mileage (13-16). Typical 4.0 OHV.
I really don't want to continue throwing parts at this thing (can't afford to for that matter), but need it for work. Any ideas are greatly appreciated.
