'94 X-Ploder S.A.S. | Ford Explorer - Ford Ranger Forums - Serious Explorations
'94 X-Ploder S.A.S.
building this cheap and with parts i have gathered. i will not be doing any serious crazy 4wheeling, but i do mud bog at certain events mostly. i run and compete in a 4 & 6 cylinder class where you cant have visible motor mods.
so far i put a 2" body lift in and i did the rear flip kit done using the stock 8.8, 31spline rear, and the center section is welded and i added a set of 4:10 gears. so with all that in the back i got 5 1/2"s of lift.
for the front we are using a d44 out of an early bronco that will be coil sprung. im going to order early bronco spring buckets and 5 1/2" lift coils, we are doing custom steering and eventually custum radius arms.
i plan to run at least 36" tires, maybe a set of swamper ssr's or iroks.
now since ill be usuaing an early bronco rear thats narrower that a full size width, tires shouldnt hang out to far right? that will be about the same as the stock 8.8 rear? or will the fronts hang out way more?
Rusty
MA
97 Xlt and 97 Sport
take and post lots of pictures!!!! Good Luck!
zainyD
Lakeland, FL
'96 Ranger 4x4 XLT
You will be right at stock width with the EB front.
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
sum pics
Rusty
MA
97 Xlt and 97 Sport
oohhhh ahhhhh... looks pretty good so far... but post as many as you can! Post some of the process, you working on it, talk about the problems you had... we just want to learn from what you're experiencing!!
Keep having fun and can't wait to see more!
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
more
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
ok ok its a pain in the ass putting pics up here... let me try this now and see if i can get a bunch up!
this is just body lifted
wacked out rear 1/4
trimmed behiind fender
body lifted on 33x10.5 boggers
body lift and flip done to rear
custom lowes snorkle
gutted carpet, and new cb
8.8 trick flow diff cover
Burns
Moderator Emeritus
Pulaski, TN
1991 Explorer/2002 F-250
Well im not the only guy running mud anymore.....
Got any pic from the events you run at
I have to run in the v8 class cause of other mods......
257_cedc3_4e2fe138_tn.jpg.thumb
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
none with the explorer, b/c its in the build process, but i have a '96 ranger 4cyl 2.3l with 3" body lift and 6" superlift with 33 10.50 boggers & 4:10's with ttb suspension i ran '07 season...
pic in action before i broke pass side front axle with 4:10's
me @ bogs
axle pics...
curent state with new 5:13 gears and welded rear and front locker
and with my daily driver 98 4.0 5spd ranger with 3" body and 33x1250 bfg muds
lifeguard379
sacremento,ca
93 eddie bauer 2 door
nice! dose the snorkle get in the way of the door opening?
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
yes it does, but soon ill have the doors off and it wont matter lol. but even if i modify some of the sections and make a better brace i can get it out and away with the door on and allow it to open with out problems
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
its nice out today and i should be wrenching
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Yeah you should! Pull the plug on the computer and get wrenching!! :D
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
well no progress really made but i did just get home from the junkyard, i bought spring buckets shock towers and coil springs out of a 78 full size bronc for $40. and the new idea is since my xploder has a salvage title that i can never get in my name, im thinking d44 and 9" full widths....
hmmmm.....
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
new parts came in...
i ordered super flex 5 1/2 " coil springs from broncograveyard.com
and i got my springs perches from atech.
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
Are those fullsize Bronco coils? Those are gonna be pretty stiff on an Explorer.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Okay .. I looked all over the BroncoGraveyard site but couldnt find the part # for the cat.
Price quote for one (1) cat with the special "Use Its Head To Hold Up A Coil Spring" modification, to zip 20876 -- thanks.
Mud_Bone
Sioux Falls, SD
2000 XLS, 97 XLT, 95 XLT
Thats the old school "cat back" exhaust system found only on the early model Broncos. They discontinued it because it made noise and smelled funny when it warmed up!!:D:
FireZapper
Columbia Pa.
93 Sport
Dude I hope the pig is treating you right!
ReDLiNeZL
Lancaster PA
'94 XLT 4DR
they are 66-77 bronco coils yes sir..
stiff? not to worried bout that for mud boggin. and its just another vehicle to build for advertisement for our shop... OFF ROAD CENTRAL..
www.offroadcentral.biz
