juggernaut2874
- November 8, 2005
- Biloxi, MS
- '94 XLT 2WD, '02 EB 2WD
My 94 XLT with 180K miles is having problems starting after it rains or when there is high humidity and since I am on the coast that is always. There are no KOEO or KOER codes and I have new fuel filter, clean K&N air filter, plugs, wires, and battery. When it is sunny and hot out, I have no problem firing it up. I put water remover in the gas tank every so often. Could moisture be getting into the coil pack or somewhere else? Could it be the FPR or a vacuum leak? Have not had a noid light on the injectors because none of the old plugs were fouled and it runs just fine when it starts. I'm at a loss.
