Ok - before you shoot me , I have already read the write-up on swapping the two out. (see http://www.4x4central.com/discrear.html)
My question is this - I am going to add a 5.5" lift when I do this swap (I want the disc brakes obviously), but my concern is the spring perches. I plan on adding new perches, welded on, and new shock mounts. How do I 1) calculate where to mount the perches, taking into account with the lift I will need to rotate the axle back to relieve some of the stress from the increased angle, and 2) measure the length for new shocks if I add shock mounts? And while we're at it - has anyone seen dual shock mounts for the rear and if so, where?
Thanks for the help guys!
Jon
Jon
